Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 7 of 7
  1. #1
    Join Date
    Dec 2008
    Location
    Jarreau, Louisiana, USA
    Posts
    9
    Default "Tohatsu Guru, What do you
    "Tohatsu Guru,
    What do you think about a 9.25 x 9 stainless steel Powertech prop for the Tohatsu 9.9, I mentioned in a earlier post ?
    Do you find the ss too hard or a danger to the gears as stated earlier ?
    Thanks,
    Greg"
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default "In general, I'm against t
    "In general, I'm against the use of SS props. People tend to buy SS with the idea that it will last longer or provide a solution to chipped aluminum props. That's the wrong way to look at at it. SS is a performance enhancer only and even then, only in specific applications. I can't think of an application on a 9.9 where SS would be a good idea unless you needed the extra 1 mph that it will give you and you only operated in deep water where there was no chance of hitting anything with it.
    I wouldn't say it is a high risk to use one....But, there is risk and the possible benefit is slight.
    I would call it a moderately bad idea."
    Elvin
    Solution One Maritime
  3. #3
    Join Date
    Dec 2008
    Location
    Posts
    9
    Default "Thanks for the reply. I pu
    I purchased a 07 G3 22'pontoon boat with a Yamaha 115 4 stroke. The dealer refused to sell me a ss prop. Gave me an extra alum. prop., for the same reason you stated.
    I have always had ss props on other motors, never had any problems. I have hit many objects, logs, stumps, sandbars etc. I guess I have been lucky.
    Another question; Using the Tohatsu 9.9 at WOT the tiller arm vibrates pretty bad. Could the old prop cause this ? It's not in the best of shape."
  4. #4
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default An out of balance or damged pr
    An out of balance or damged prop will add to any existing vibration and make it worse.
    Elvin
  5. #5
    Join Date
    Dec 2008
    Location
    Posts
    9
    Default "Tohatsu Guru, Many Thanks
    "Tohatsu Guru,
    Many Thanks for your time and all the info.
    Greg "
  6. #6
    Join Date
    Apr 2008
    Location
    Posts
    161
    Default "If you are going to get the p
    "If you are going to get the prop repaired or even buy new ask to repairer to add some cupping to the blades,It will give you noticeable more grip with the 9.9"
  7. #7
    Join Date
    Dec 2008
    Location
    Posts
    9
    Default "Thanks david .<[img]"http://w
    "Thanks david ."
Similar Threads
  1. Duo prop to single prop question
    By glastron24css92 in forum Volvo Penta Gas Archive
    Last Post: 07-23-2009, 12:39 PM
  2. Prop install and prop size
    By birdy916 in forum Mercruiser Sterndrive Archive
    Last Post: 06-10-2009, 07:20 AM
  3. Volvo Penta Duo Prop DPS Prop Installation
    By njfishing in forum Volvo Penta Gas Archive
    Last Post: 04-30-2009, 10:05 AM
  4. SP TO DUO PROP
    By claudio in forum Volvo Penta Gas Archive
    Last Post: 04-06-2008, 10:19 PM
  5. Trying to determine diameter and pitch of prop on 85HP Johnson from number stamped on prop
    By Bob Padowicz in forum Johnson Evinrude Outboard Archive
    Last Post: 07-29-2006, 11:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
