Click for Honda Manuals, Parts and Model Guides!
Results 1 to 3 of 3
  1. #1
    Join Date
    Nov 2008
    Location
    Kaneohe, Hawaii, United States
    Posts
    2
    Default I just purchased a honda 225 o
    I just purchased a honda 225 outboard and was wondering what the break in period is. Thanks.
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    3,928
    Default "I don't have my manual wi
    "I don't have my manual with me, but if my memory is correct it's 20 hours and do not exceed 5000 rpm. Then change engine oil and filter, change lower end oil, check fuel filter and fuel-water seperator filter, check timing and idle (650 rpm). Typically the dealer would and should do that."
    CHawk 25 DLX
  3. #3
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,114
    Default "Here's the good word dire
    "Here's the good word directly from Honda..
    This should all be in your owners manual, that is unless you bought the motor in a back alley somewhere at a really really good price...
    If you don't have the manual get one and read it more than once. Most 4 strokes end up as junk because owners fail to follow the recommended service "to the letter". A 4 stroke is not forgiving the way a 2 stroke is - neglect it and it will quickly turn into a few hundred pounds of scrap metal...
    BREAK-IN PROCEDURE
    Break-in period: 10 hours
    Break-in operation allows the moving parts to wear-in evenly and thus ensures proper performance and longer outboard motor service life.
    First 15 minutes:
    Run the outboard motor at trolling speed. Use the minimum amount of throttle opening necessary to operate the boat at a safe trolling speed.
    Next 45 minutes:
    Run the outboard motor up to a maximum of 2,000 to 3,000 rpm or 10 %to 30 %throttle opening.
    Next 60 minutes:
    Run the outboard motor up to a maximum of 4,000 to 5,000 rpm or 50 % to 80 % throttle opening. Short bursts of full throttle are acceptable but do not operate the motor continuously at full throttle.
    Next 8 hours:
    Avoid continuous full throttle operation (100 % throttle opening). Do not run the outboard motor at full throttle for more than 5 minutes at a time.
    For boats that plane easily, bring the boat up on plane then reduce the throttle opening to the specified break-in settings called out above."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
Similar Threads
  1. BF15 Break In
    By marlinmike in forum Honda Outboard Forum
    Last Post: 11-29-2009, 10:49 PM
  2. Engine break in
    By belliswood in forum Crusader Marine Engine Forum
    Last Post: 09-08-2009, 03:53 PM
  3. Break in
    By dave_rose in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-28-2008, 06:42 AM
  4. Break in
    By macbarber in forum Johnson Evinrude Outboard Archive
    Last Post: 06-04-2006, 07:10 AM
  5. Break down book on the net
    By nick in forum Archive 2003-2009
    Last Post: 02-29-2004, 08:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
