Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 5 of 5
  1. #1
    Join Date
    Jan 2008
    Location
    beaufort, south carolina, usa
    Posts
    40
    Default "Hello, I am going to clean an
    "Hello, I am going to clean and soak my carb,3.5 four stroke,Question is there a float ajustment on this carb thanks ."
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default Yes...Make sure it is set leve
    Yes...Make sure it is set level.
    Elvin
    Solution One Maritime
  3. #3
    Join Date
    Jan 2008
    Location
    Posts
    40
    Default Thank you for your reply Tohat
    Thank you for your reply Tohatsu Guru. Level with the carb body when upside down? Thanks again
  4. #4
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default Da
    Da
    Elvin
  5. #5
    Join Date
    Jan 2008
    Location
    Posts
    40
    Default thanks again
    thanks again
Similar Threads
  1. Float for my carb
    By chuck4412 in forum Chrysler Force Outboard Forum
    Last Post: 05-01-2009, 10:34 PM
  2. Float losing buoyancy What would be the symptoms of a bad carb float
    By tcarpe1 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-21-2009, 11:46 AM
  3. Carb Float
    By mopar_nocar in forum Johnson Evinrude Outboard Archive
    Last Post: 07-09-2008, 05:52 PM
  4. Carb float
    By adam blantz in forum Suzuki Outboard Archive
    Last Post: 07-08-2007, 07:07 PM
  5. Carb Float Height
    By Richard Stickley in forum Suzuki Outboard Archive
    Last Post: 02-21-2006, 03:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
