MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Join Date
    Dec 2008
    Location
    Toledo, Ohio, USA
    Posts
    2
    Default "Has anyone ever converted the
    "Has anyone ever converted their standard pull start outboard to an electric start? We have a 1999 40hp 4 stroke Merc that can be pretty cranky when it gets cold....we've snapped the rope a few times this year because she's so hard to pull in the early morning cold....
    So were looking to try to add a starter and what not to the motor to convert it to an electric start. Obviously need the starter, assuming we need a new flywheel to match up with the starter....are there any other components that need to be swapped out to make the conversion work? I've heard the electrical system (or at least the stator assy will need to be exchanged)
    We've found starters about about $100....if we can find a flywheel they are pretty pricey...
    anybody know of anyone that has used or refurbished merc parts...trying to save some coin as we can't afford to buy everything new...."
  2. #2
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "Is this you, your not going t
    "Is this you, your not going to find better info.
    Convert from Pull Start to Electric - 40 Hp 4strk
    11/30/08 at 12:55:37 Quote I think I may have asked this question in the past, but I could not find the thread so I wanted to post up again. Currently we have a 40 hp 4 strk, 99 MY, on our duck boat. When it is cold out it can be a pain to start and we want to convert if from a pull start to an electric start. I am pretty handy with motors and we have already rebuilt the power head on this motor once so I think I know my way around it. The block has the mounting holes for the starter already in place and they are tapped as well. From what I can tell I think all we need a new fly wheel and a starter along with the solenoid.
    For the fly wheel I think it is part number 284832010T29
    Starter - 50859170T1
    Solenoid - 89850187T1
    Can anyone think of anything else in terms of Items that I must buy from Merc? Maybe the batt cables vs. making them?
    Thanks for all of the help.
    JD
    Back to top Personal Message IP Logged
    The Marine Doctor
    YaBB Administrator
    Gender:
    Re: Convert from Pull Start to Electric - 40 Hp 4s
    Reply #1 - 11/30/08 at 12:57:27 Quote I need the serial number of your engine to see if there is a kit made.
    The Marine Doctor
    Back to top
    Please remember I put a lot of time and effort into the forum along with my own money....It's free advice unless you want to donate Email | Personal Message | WWW IP Logged
    Merc_Nut
    Global Moderator
    tuN yrucreM
    Gender:
    Reply #2 - 11/30/08 at 13:29:59 Quote Assuming you're not looking at the charging system, the parts you list appear to be correct, but like The Marine Doctor says we'll need to serial number to confirm the flywheel reference.
    Bolts to hold the starter on are M8x45 (3x)
    Bolts to hold the solenoid on are M6x30 (2x)
    You might want to consider the factory cable between the solenoid and the starter. p/n 93388A13. Might be a pain to reproduce.
    The negative and positive from the battery to the motor can be picked up relatively cheap at any marine store.
    Don't forget you'll need a switch or button to start it with as well.
    Back to top
    Note: I'm not a mechanic...just a Merc nut trying to provide advice.
    '72 Glastron GT160 c/w '72, '84 & '86 115hp Merc
    '70 9.9hp , '70's 20hp , and '61 50hpEmail | Personal Message IP Logged
    reelnaughty
    Guy who cleans up the mess
    I love YaBB 1G -
    SP1!
    Reply #3 - 11/30/08 at 17:00:04 Quote Ok, I will see if I can get the serial number. The boat is not at my house so it may take a day or two.
    Thanks!
    JD
    reelnaughty
    I love YaBB 1G -
    SP1!
    Reply #4 - 11/30/08 at 17:47:12 Quote Ok, here is the serial number;
    Either
    06878560
    OG878560
    The Marine Doctor
    YaBB Administrator
    Gender:
    Reply #5 - 11/30/08 at 17:58:45 Quote No kits avail.
    All has to be priced out.
    I would assume over 1k for starters, given that you need the starter and flywheel for sure.
    Also...a different stator
    The Marine Doctor
    Back to top
    reelnaughty
    I love YaBB 1G -
    SP1!
    Reply #6 - 11/30/08 at 18:29:53 Quote I was able to find a starter for $100, and possibly a used flywheel for around $100, but the stator is a bummer. Didn't realize until you mentioned it that a new stator was required. May have to do some more digging. Any idea of an outboard junkyard of sorts that may have a blown powerhead motor sitting around that I could pirtate that parts off of?
    JD
    The Marine Doctor
    YaBB Administrator
    Gender:
    Reply #7 - 11/30/08 at 19:10:58 Quote No sorry none. I am surprised that you found used stuff at all.
    The stator may? be purchased at CDI aftermarket.
    The Marine Doctor
    Back to top
    Pages: 1 Reply | Add Poll | Notify of replies | Add to Favorites | Send Topic | Print | Mark as Unread
    The Marine Doctor OutBoard Motor Forum Mercury/Mariner (Moderators: Merc_Nut, Spinnerbait_Nut) Previous topic | Next topic
    The Marine Doctor Powered by YaBB 2.2!
    YaBB 2000-2007"
  3. #3
    Join Date
    Dec 2008
    Location
    Toledo, Ohio, USA
    Posts
    2
    Default "wow, sorry thats one of my bu
    "wow, sorry thats one of my buddies who apparently asked the same question on this site. I was referred to this site from someone else and didn't know he had already posed the question here...He's a long hour working company man...so I don't get a chance to talk to him unless we're out hutning or fishing...regardless thanks a lot for the detailed responses!!"
  4. #4
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "No problem, they answered the
    "No problem, they answered the question better than I ever could."
Similar Threads
  1. From pull start to electric start 2004 30 hp
    By soapy in forum Johnson Evinrude Outboard Forum
    Last Post: 03-04-2010, 04:05 PM
  2. Evinrude pull start out board to electrical start outboard
    By Nicholas Prom in forum Johnson Evinrude Outboard Archive
    Last Post: 07-19-2008, 08:56 AM
  3. Pull start to electric
    By kevint in forum Johnson Evinrude Outboard Archive
    Last Post: 02-22-2008, 08:55 PM
  4. Converting from manual start to electric start
    By Glen Mc in forum Mercury Mariner Outboard Archive
    Last Post: 03-10-2006, 01:14 AM
  5. Converting 1996 25hp Johnson pull start to electric
    By jerry in forum Johnson Evinrude Outboard Archive
    Last Post: 04-19-2003, 09:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
