Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 6 of 6
  1. #1
    Join Date
    Oct 2007
    Location
    Genoa / Gibsonburg Ohio, Ohio, USA
    Posts
    49
    Default "The new issue sale flyer at H
    "The new issue sale flyer at Harbor Freight has one for $24.95. Reading the specs I find it is for 3 cylinder motors and up.
    Of course I have three outboards to play with this winter ,, 2 one cylinder and one two cyc.
    DIY're Lake Erie."
  2. #2
    Join Date
    Sep 2008
    Location
    wouldnt you like to kno, not sure, the usa
    Posts
    87
    Default i dont know chuck its probabl
    i dont know chuck its probably junk and wont do what you want if all your engines are Nissan id just get a Nissan tach if there other manufactures then get a teleflex tach to run them accurately on two stroke carbs nissans to get an accurate reading at idle you need to remove the voltage regulator it screws with the tach at idle but over 2000 its accurate if set correctly
  3. #3
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default Nissan's don't have vo
    Nissan's don't have voltage regulators.
    Elvin
    Solution One Maritime
  4. #4
    Join Date
    Aug 2008
    Location
    Freeport, Pa, USA
    Posts
    51
    Default Hardline products has a combo
    Hardline products has a combo tach and hourmeter
    for around $50.Best price I found was at
    A&D discount performance.
  5. #5
    Join Date
    Oct 2007
    Location
    Posts
    49
    Default "Hummmm,,,,,,,? The three eng
    "Hummmm,,,,,,,? The three engines I'm monkey'n with is an '86 2 cyl yachtwin 2-stroke Evinrude 6 HP with CD2 A newer 5 HP Honda 1 cyl 4-stroke and this looks to be an exact copy of the third engine, 2003 Nissan 5 HP 4-stroke. Would you beleive because I could not get the Honda to idle slow enough ,,, ( because of old gas dirtied up the low speed jets ) I ended up shearing the pin and had nothing when docking my sailboat. I definatly see an advantage in having the rubber hub style propellor that the Nissan has. Neither 4-strokes shift as nicely as the evinrude,. So has anyone used this tach on these engines?
    http://ad-discountperformance.com/in...22c32ae6fab8f3"
  6. #6
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,127
    Default Yep - those are a knock-off of
    Yep - those are a knock-off of the "Tiny Tach" which has been around for years. They work fine on 1 and 2 cylinder 2 stroke motors. I don't play with 4 strokes so have never bothered to see if they make a compatable (gauge).
    The pickup wire wraps around the number 1 spark plug lead (or the only lead if it's a single) so works regardless of what type of ignition you have...
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
Similar Threads
  1. Fluke Meter as Tachometer
    By wirenut2266 in forum Miscellaneous marine engine topics
    Last Post: 08-12-2008, 06:46 PM
  2. Hour meter
    By dan brasfield in forum Yamaha Outboard Archive
    Last Post: 01-11-2008, 03:30 PM
  3. Hour Meter
    By rammyii in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-16-2007, 06:58 AM
  4. Inexpensive prop for 1968 65 Horse Evinrude
    By joe in forum Outboard motors archive 2000-2004
    Last Post: 10-24-2000, 01:52 PM
  5. Need inexpensive carb syn tool
    By JUSTINTIME in forum Honda Outboard Archive
    Last Post: 12-31-1969, 07:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
