1999 25hp Suzuki No Spark at All
mmanevbg
"Hi There,
i just bought a bo
"Hi There,
i just bought a boat but the motor doesn`t start.The motor hasn`t been started for a while.I checked and found that there is no spark at any of the 3 cylinders.
Can somebody give me an idea what i can do to solve this.
Thanks in Advance!!!"
It has a starter and a rope.Th
It has a starter and a rope.The starter actually works fine but there is no spark to neighter one of the 3 cylinders.
any clues? I hope is not the ignition unit?!?!
"First off, I am not a mechani
"First off, I am not a mechanic, more of a broke do-it-yourselfer, so this is not professional advice, just my experience I had with an 86 DT25 with a similar problem. I don’t know if there are safety sensors that might shut down a 99, but if not try this. Check the kill switch 1st. if your not sure if its working, cut the 2 wires leading to it and twist them together. remove the plugs so it doesn’t accidentally start and check for spark at the plug while you turn it over. If no spark, check the stator. Isolate the rectifier wires, they will not impede spark so don’t even bother with them. Find the 2 wires that come from under the flywheel from the stator. On mine, they were black and red. Hook up voltmeter probes, one to each wire, and turn it over. If you get voltage, the stator generator is good and supplying the CDI with power. The hard part is figuring out if the problem is the CDI or the ignition/timing switch. My suggestion is replace the Ign/Timing switch. You may have to take off the flywheel, depending on the location, like I said, my model was older, and I am not familiar with the 99. The Ign/timing switch is much cheaper $ to replace than the CDI. Once replaced, check for spark again. If none, it is probably the CDI. Hope this helps."
I fixed it.Actually the kill s
I fixed it.Actually the kill swith was messing up.
Thanks for the advice Blackbetty!!!
Thanks!
