Timing
yak07
"Can somebody tell me what deg
"Can somebody tell me what degree to set the timing on a 1991 120hp force with prestolite magneto ingnition? I don't know wheter to set it on 28, 30, or 32 degrees."
"Larry, if you are still looki
"Larry, if you are still looking for the answer your max timing will be 30 at cranking speed or 32 with the motor running..."
Mine has the three lines inste
Mine has the three lines instead of degrees. I have no idea which line to put it on. Might just take it to the shop. Keeps backfiring when I try to start it.
i have a 78 chrysler 105 and c
i have a 78 chrysler 105 and can not get it to fire im not sure if it is the timing or if something went wrong. i was on the lake when it came to hault i could not get it to start or get fire after that i talked to a local boat shop and they said it was the pre amp so i replaced it and no change i really need some help on this
