Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 10 of 10
  1. #1
    Join Date
    Dec 2008
    Location
    west monroe , louisiana, usa
    Posts
    6
    Default i have a 2000 50 that stalls a
    i have a 2000 50 that stalls at idle but runs great at wide open throttle
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default "Tim, A low speed problem c
    "Tim,
    A low speed problem could be anything from a clogged jet in a carburetor to a bad spark plug. You will need to troubleshoot the engine's system's to find out which system is giving the problem. Then you start testing the individual parts of that system."
    Elvin
    Solution One Maritime
  3. #3
    Join Date
    Sep 2008
    Location
    wouldnt you like to kno, not sure, the usa
    Posts
    87
    Default what rpm does it idle at mine
    what rpm does it idle at mines idles around 1000 1100 in neutral might be as simple as tweaking the screw on top of the top carb
  4. #4
    Join Date
    Dec 2008
    Location
    Posts
    6
    Default it idles at 1100 rpm has new
    it idles at 1100 rpm has new plugs new fuel filter fresh gas new fuel line and primer bulb and i rebuilt the fuel pump last week i orderd a carb rebuild kit for all 3 carbs today
  5. #5
    Join Date
    Sep 2008
    Location
    Posts
    87
    Default did you check your mixture nee
    did you check your mixture needles they should be around 2/12 to 3 turns out from loosely seated but higily doubt there not adjusted right you can turn them 2 turn each way and not make a difference
  6. #6
    Join Date
    Dec 2008
    Location
    Posts
    6
    Default they are turned out 2 1/2 turn
    they are turned out 2 1/2 turns
  7. #7
    Join Date
    Sep 2008
    Location
    Posts
    87
    Default well does it just die at idle
    well does it just die at idle my idles are set a little low in my opinion it will idle dead idle for probably 5-10 mins before it cuts off if i raise the idle rpm it will idle forever but the boats going to fast for trolling so did you try bumping your idle up just a tad im running a 15 inch pitch stainless wheel and im probably idling 1000 in gear so maybe im 1200 in neutral i cant say for sure but if it runs great every other speed it might just need to be bumped up but if you need to choke it to keep it idling then you probably need to rebuild the carbs i highly doubt it ignition do you run a big racor fuel filter if so theres your issues nissans dont like those huge racor filters
  8. #8
    Join Date
    Dec 2008
    Location
    Posts
    6
    Default it stalls out when you put it
    it stalls out when you put it into gear i still have the stock fuel filter on it i just replaced the filter element in it it needs to be choked to stay running
  9. #9
    Join Date
    Dec 2008
    Location
    Posts
    6
    Default thanks for all the help it was
    thanks for all the help it was greatly appreciated i will rebuild the carbs this weekend and let yall know if it worked thanks tim cook
  10. #10
    Join Date
    Dec 2008
    Location
    Posts
    6
    Default the carb rebuild worked proble
    the carb rebuild worked problem solved no more stalling it runs like new
Similar Threads
  1. 2000 Yamaha 150 OX66 stalling out
    By quadzilla1000 in forum Yamaha Outboard Archive
    Last Post: 06-02-2008, 02:21 AM
  2. 2000 Yamaha f100 stalling at low idle
    By ibuoy in forum Yamaha Outboard Archive
    Last Post: 05-14-2008, 12:14 AM
  3. 454xli stalling above 2000 RPM
    By John Gentile in forum Crusader Marine Archive
    Last Post: 02-01-2008, 09:46 AM
  4. OMC 140 Horse stalling at higher speed
    By Al Westerlund in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-29-2006, 01:44 PM
  5. 2000 90 HP JOHNSON HARD START AND STALLING NO POWER
    By BOB GALLOWAY in forum Johnson Evinrude Outboard Archive
    Last Post: 07-06-2006, 10:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
