Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 7 of 7
  1. #1
    Join Date
    Nov 2008
    Location
    Santa Ana, ca,
    Posts
    4
    Default "The motor will start on the f
    "The motor will start on the first pull. When I got the motor the fuel inlet passage going from the fuel line attachment to the float bowl was full of salt. I cleaned it all out, blew out all the jets and replaced the needle and seat. When I pump the fuel into the carb the fuel bulb gets nice a firm, so I know the needle is seating. Now the motor runs, but when I turn the throttle up, it starts to smoke profusely, and the rpms dont increase that much. I think it is flooding, but dont know why if the needle is seating. However If I keep the throttle up eventually the motor will revs up but not without barrels of smoke. It is just strange, because it will idle all day real nice. The fuel mixture is at 50:1. Should I replace the carb, soak the current one in paint thinner? could the timming or anything else cause this?"
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default "If it's smoking you eithe
    "If it's smoking you either have a problem with the block/rings, reeds or too much oil in the gas. Cleaning the carb again is a good idea, only use carburetor cleaner."
    Elvin
    Solution One Maritime
  3. #3
    Join Date
    Nov 2008
    Location
    Santa Ana, ca,
    Posts
    4
    Default "The fuel mixture is right and
    "The fuel mixture is right and I have cleaned the carb three times. Do you think the reeds are sticking, not allowing enough air, but fuel is getting in causing the motor to run overly rich? Should I clean the reeds or replace them. thanks for the quick reply."
  4. #4
    Join Date
    Nov 2008
    Location
    Santa Ana, ca,
    Posts
    4
    Default "In addition, wouldn't rin
    "In addition, wouldn't rings cause crappy compression resulting in a motor that is hard to start?"
  5. #5
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default "Sticking reeds are so rare as
    "Sticking reeds are so rare as to be unheard of in outboards. You might have a bent or cracked reed...but, that would be unlikely. However, checking them would be a good idea. As to a stuck ring giving you low compression. Often it will, but not always. The key to this is the elimination of one system, at a time, to find the problem area.
    "the float bowl was full of salt."
    Think in terms of a mechanical problem with the power head as the engine almost certainly was abused prior to you getting it."
    Elvin
  6. #6
    Join Date
    Nov 2008
    Location
    Santa Ana, ca,
    Posts
    4
    Default "Yeah, I am sure it was abused
    "Yeah, I am sure it was abused. the float bowl wasnt full of salt but the passage leading to the float bowl was, or at least I think it was salt, I didnt taste it. The salt was blocking fuel from reaching the float bowl, I thought once I cleared it I was home free, then the motor did this. I will tear down further and check out the reeds.
    I cant rationlize that it has anything to do with the rings, crank, wrist. It has to be something with fuel to air ratio. which I am thinking too much fuel and not enough air considering the amount of smoke. I have never seen a motor do this, idle nice and rev like crap."
  7. #7
    Join Date
    Sep 2008
    Location
    wouldnt you like to kno, not sure, the usa
    Posts
    87
    Default idk i changed the rings in my
    idk i changed the rings in my 5hp mod motor they where shot the motor original came from a sand company breathed in too much sand didnt mess the cylinder up just the rings they were really wore but it still ran and really good was alittle hard to start when cold but ran good i shaved 15 thousands off my cylinder head and now she really powerful and easy to start dont smoke as much either just check everything though
Similar Threads
  1. H99 starts great idles great stops after 5 mins hard to restart
    By sailorickm in forum Honda Outboard Forum
    Last Post: 09-26-2009, 11:10 PM
  2. Suzuki 25 2v 4 stroke idles great will not run
    By fire_capt_al in forum Suzuki Outboard Archive
    Last Post: 03-16-2009, 06:25 PM
  3. Classic 50 idles great no high drive
    By Mike Ammons in forum Mercury Mariner Outboard Archive
    Last Post: 07-13-2008, 11:54 PM
  4. 96 JOHNSON STARTS GREAT IDLES GREAT LACKS POWER WHEN GIVING THROTTLE
    By craig madden in forum Johnson Evinrude Outboard Archive
    Last Post: 08-30-2007, 05:48 PM
  5. 90 hp mercury 4 stroke 2000 stalls when accelerates
    By stockman157 in forum Mercury Mariner Outboard Archive
    Last Post: 02-21-2006, 02:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
