6V 92 TA Leaks oil everywhere
bulit7
"Has anyone seen this? It leak
"Has anyone seen this? It leaks oil from everywhere, both engines... Is this comon?
Where do I start? Some leaks require major disassembly to get to..."
"All I can say is clean it, fi
"All I can say is clean it, fire it up, and find out where the worst leaks are coming from. Either degreaser and a pressure washer or lots and lots of brake cleaner.....and go from there."
yes what Jimmy is telling you
yes what Jimmy is telling you to do is the best way to solve the problem i had the same problem on 671n after i cleaned the engine i found the bigest leak was the accesory drive pulley i changed the seal and 90% of oil in the bildge was gone.
