4 Cylinder Gray Marine
theodolite
I have a 1939 Century 15'
I have a 1939 Century 15' Utility with a 4 Cylinder Gray Marine Engine. Continintal block. I am changing out the head and need to know the amount of torque to use and if there is a sequence on the bolts. I will buy catalogue if I knew which one gives me the data.
"Hello, The head bolt torque i
"Hello, The head bolt torque is 45-48 ft lbs. Valve adjustment is .017 both. Call Engine center 2351 Hilton Ferndale Mi. for parts. 248-399-0002. You need the engine model number. It took me a year to find this information,good luck."
