"Thank you, Graham!!! I am ver
"Thank you, Graham!!! I am very grateful as I am not familar with the Mercury line. I am replacing a 75HP Evinrude with this 90HP Mariner, so I'm starting from the beginning as far as Mercury motors. I am missing the tilt tube on the Mariner and am not sure if my tube from the Evinrude is compatible with the Mariner,as well as the Steering cables.
I've been told the motor has been not used for two or three years, so I plan to change the Water pump, plugs,change lower unit oil, as well as run it with mixture of gas and oil to insure the oil injection is fuctional.
Any thoughts are appreciated. Thank you, Steve"
