Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 6 of 6
  1. #1
    Join Date
    Jul 2008
    Location
    Eastham, massachusetts, usa
    Posts
    6
    Default "Hi. My motor peiodically soun
    "Hi. My motor peiodically sounds like its cavatating, highrevs but not going anywhere- also shifting hard. Any thoughts? Also, can someone tell me how to read the oil level/water pressure warning gauge...I'm new to this motor. I have all green dots lit up- I assume means full oil level, but what do the two red water lights mean? The motor is peeing just fine and not overheating. The light on the right seems to be slightly glowing, one on left goes off."
  2. #2
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default might be spun prop do you shi
    might be spun prop
    do you shift slowly?
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  3. #3
    Join Date
    Jul 2008
    Location
    Posts
    6
    Default "Wow, now that you mention it,
    "Wow, now that you mention it, I had been having engine troubles this past september and in an effort to get back home had to rev up the motor high and quickly shift it into gear before it died. I just got the motor back from the shop where the carbs were rebuilt. This problem I am referring to just began on my trial run after getting the boat back. What's the best way of checking this out? Can I run the motor in gear with the muffs on?"
  4. #4
    Join Date
    Sep 2006
    Location
    Posts
    8,649
    Default no you need to water test it
    google spun prop
  5. #5
    Join Date
    Jul 2008
    Location
    Posts
    6
    Default I pulled the prop and brought
    I pulled the prop and brought it to a shop. The guys said there was nothing wrong with it. I changed the lower unit oil and no metal fillings came out with the old oil. I haven't put the boat back in the water yet to re-test it. Any thoughts?
  6. #6
    Join Date
    Sep 2006
    Location
    Posts
    8,649
    Default i think one is overheat and on
    i think one is overheat and one is no water pressure
Similar Threads
  1. DT100 lower end interchange or WTB DT100 lower end
    By sundown57 in forum Suzuki Outboard Archive
    Last Post: 10-15-2008, 08:48 PM
  2. Drive isnbt quite coming out of gear
    By elgineddie in forum Mercruiser Sterndrive Archive
    Last Post: 08-11-2008, 09:36 PM
  3. Water is coming out of the top of the head on my 1989 125HP
    By nightstalker133 in forum Chrysler Force Outboard Archive
    Last Post: 05-18-2008, 05:47 PM
  4. 89 bayliner capri 23 cobrasticks coming out of gear
    By Darryl k in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-16-2007, 10:17 AM
  5. 1980 50 hp mercdoes not want to go in gear and has grey oil coming from exhaust
    By Alden Belcher in forum Mercury Mariner Outboard Archive
    Last Post: 05-22-2007, 09:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
