Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 2 of 2
    Aug 2008
    Palm Coast, FL, USA
    Default "Hi, I can't get the gea
    I can't get the gear case all the way up on my 2001 Tohatsu longshaft 4hp 4 stroke. I can get it up most of the way, then the top of the drive shaft strikes the gear shift linkage up on top with a click I can feel with my hand on the lever. The cam rod joint clamp bolt is loose. Any advice will be appreciated.
    Jun 2007
    Default There is no trick to this. You
    There is no trick to this. You just have to keep trying until you get the drive shaft and shift rod lined up.
    Solution One Maritime
  1. What does gear case fit
    By martin2561 in forum Mercury Mariner Outboard Archive
    Last Post: 11-12-2007, 02:32 AM
  2. Reinstalling my lower case
    By neilm in forum Mercruiser Sterndrive Archive
    Last Post: 04-15-2007, 11:26 PM
  3. Reinstalling gear shift rod HELP
    By northrivergeek in forum Johnson Evinrude Outboard Archive
    Last Post: 02-13-2007, 06:59 PM
  4. Omc upper gear case ball gear shaft assy
    By richard tucker in forum OMC Sterndrive and Inboard Archive
    Last Post: 01-11-2007, 10:17 PM
  5. Gear oil leaking above gear case
    By Richard Clark in forum Archive 2003-2009
    Last Post: 04-16-2004, 08:57 AM
