Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 4 of 4
  1. #1
    Default "I have a new 9.8 that I run r
    "I have a new 9.8 that I run regularly, and has been running good. I have noted that the top spark plug gets a lot dirtier than the bottom plug. Last time out I pulled the plug mid way thru the day and cleaned the plugs. It made a huge difference. Do these plugs need to be cleaned after each use?
    What about running a hotter plug? I just went over the 10 hour break in and am about to change the oil and filter. Thanks for your advice."
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default ""Do these plugs need to b
    ""Do these plugs need to be cleaned after each use?"
    Nope, average person gets 100 plus hous per set.
    "What about running a hotter plug?"
    You would be better off to have a dealer find out what the problem is and correct it rather than putting a hole in your piston with a hotter plug."
    Elvin
    Solution One Maritime
  3. #3
    Default "Well I can have it looked at,
    "Well I can have it looked at, it's still under warranty. But why would it foul after one days use?"
  4. #4
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default Possible reasons: Turning t
    Possible reasons:
    Turning the engine so that the engine oil in the crankcase got into the combustion chamber.
    Over filling the crankcase.
    Bad spark plug or improperly gapped spark plug.
    Weak spark on that cylinder.
    Elvin
Similar Threads
  1. MercCruiser runs very, very rich 1989 4.3
    By me2633 in forum Mercruiser Sterndrive Forum
    Last Post: 06-21-2010, 05:57 PM
  2. Nissan 99 runs good for a while
    By somers12 in forum Nissan Tohatsu Outboard Forum
    Last Post: 03-17-2009, 08:33 AM
  3. 8HP runs too rich
    By spanishstroll in forum Yamaha Outboard Archive
    Last Post: 09-14-2008, 08:35 PM
  4. Nissan 99 runs good one day bad the next
    By somers12 in forum Nissan Tohatsu Outboard Archive
    Last Post: 07-14-2008, 01:38 PM
  5. b94 Mariner 25 runs too rich
    By suds_mcgee in forum Mercury Mariner Outboard Archive
    Last Post: 06-28-2008, 05:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
