Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 2 of 2
  1. #1
    Join Date
    Aug 2008
    Location
    Freeport, Pa, USA
    Posts
    51
    Default My 2008 9.8 Tohatsu runs at ab
    My 2008 9.8 Tohatsu runs at about 5100 rpm at
    full throttle.Would changing the propeller pitch
    give me more rpm's?If so do I go up or down with
    the pitch number?It has the factory prop on it
    now that I believe is an 8.5 pitch.
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default Dropping down in pitch will ra
    Dropping down in pitch will raise your RPM. Dropping down to the 6.5 pitch should put you at around 5500 RPM which is the middle of the operating range for your model.
    Elvin
    Solution One Maritime
Similar Threads
  1. 85 hp Propeller pitch
    By wynand_n in forum Suzuki Outboard Forum
    Last Post: 11-06-2009, 12:22 PM
  2. 85 hp Propeller pitch
    By wynand_n in forum Johnson Evinrude Outboard Archive
    Last Post: 11-02-2009, 05:31 AM
  3. Propeller Pitch
    By colriverrat in forum Suzuki Outboard Archive
    Last Post: 12-31-2008, 02:45 AM
  4. What pitch propeller
    By heavy_473 in forum Yamaha Outboard Archive
    Last Post: 09-11-2008, 10:02 AM
  5. Propeller pitch
    By webenergy in forum Johnson Evinrude Outboard Archive
    Last Post: 06-09-2007, 11:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
