Click for Volvo Penta manuals!
Results 1 to 3 of 3
  1. #1
    Join Date
    Nov 2008
    Location
    Denmark
    Posts
    2
    Default "I want to connect my Navman c
    "I want to connect my Navman chartplotter to the evc computer so that i can have speed and mileage readouts in the tach. The manuel says it is possibel to transfer the nmea data between the two, but nothing about how, can anyone help?"
  2. #2
    Join Date
    Sep 2007
    Location
    London U.K.
    Posts
    4
    Default "Yes, the later Navman is NMEA
    "Yes, the later Navman is NMEA 2000 compatible but thr D4 is J1939 canbus and they don't speak the same language, you need the Volvo converter which plugs into the ECU and converts the J1939 to NMEA 2000 and the Navman cable from that to your plotter. I did this with the Ramarine C120 and it was plug and play. I also took the oportunity to fit an NMEA2000 backbone at the same time using devicenet cabling and plugs.By the way I sourced the Volvo converter in the States at a quarter of the UK price, I imagine Danish prices will be just as mad as UK"
  3. #3
    Join Date
    Jul 2009
    Location
    Madrid, Madrid, Spain
    Posts
    4
    Default "Hello David, would you pleas
    "Hello David,
    would you please post info about the parts you used to connect the NMEA2000 twistlock connector in the Volvo interface to your C-series Display? I need to connect it to a C70. I already have the Volvo interface but don't know if I can connect it directly to the Seatalk2 connector in my C70 or I do need a full NMEA2000 network.
    By the way, did you use Y-split cable to connect the adapter to the volvo engine or there is some way to connect it directly? (I have a Volvo D1-20B; I don't know if the EVC unit has just one connector, which is used by Volvo display fitted outside, or there is some hidden second connector for extras like the NMEA2000 interface)
    Thanks for any help,
    Ignacio"
Similar Threads
  1. 90 hp johnson connecting rod cap
    By clayvogt in forum Johnson Evinrude Outboard Archive
    Last Post: 04-05-2009, 11:04 PM
  2. Broken connecting rod
    By greatbay_fish_slayer in forum Yamaha Outboard Archive
    Last Post: 10-24-2008, 10:08 PM
  3. Connecting two outdrives
    By lezmtaylor in forum Volvo Penta Gas Archive
    Last Post: 07-24-2008, 07:48 PM
  4. Connecting Tach Help
    By walleyes4u in forum Johnson Evinrude Outboard Archive
    Last Post: 03-25-2007, 08:24 AM
  5. AQ 131 connecting rod torque
    By double_g in forum Volvo Penta Gas Archive
    Last Post: 02-02-2007, 10:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
