Results 1 to 3 of 3
  1. #1
    Default "I am currently in the early s
    "I am currently in the early stage of repowering my Hunter 27 with a Yanmar 2GM. I currenlty have a Renault engine and have just purchased a Yanmar 2GM. I am wondering if there are others that have already performed the same repower? If so, I am looking for advice, comments, and how too's and what to avoid suggestions. I will be sharing more as I work on the new (used) 2GM and begin to take out the Renault. My initial plan is to have both engines sitting side by side, check and alter my mounting beds and verify all mounting and alignment dimensions."
  2. #2
    Join Date
    Dec 2005
    Location
    Vancouver , British Columbia , Canada
    Posts
    129
    Default "Hello Russell, Keep
    "Hello Russell,
    Keep in mind that Yanmar will turn a right handed propeller. I am not sure what rotation is the Renault. Did you get the original Yanmar Motor Mounts?"
  3. #3
    Default "Hi Ronald, Yes I got the ori
    "Hi Ronald,
    Yes I got the original Yanmar Motor Mounts along with the control panel and wiring harness. Also the Yanmar owner's manual. I will have to verify that the Renault is a right handed prop. I will check that out tonight. Thank you."
Similar Threads
  1. Renault RC 240 DIS INFORMATION
    By mbarakbobo in forum Renault
    Last Post: 09-13-2014, 08:14 AM
  2. Renault Marine Gas Engines
    By Piet Jan van Wier in forum Archive 2002-2006
    Last Post: 03-07-2011, 10:43 AM
  3. HELP RENAULT RC 145 DTS
    By bnet in forum Renault
    Last Post: 03-06-2011, 04:45 PM
  4. Renault engine parts
    By hansenc in forum Mercruiser Sterndrive Archive
    Last Post: 07-09-2009, 08:59 PM
  5. Nanni Renault 390H
    By Cliff Sutton in forum Renault
    Last Post: 04-20-2007, 05:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
