Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 7 of 7
  1. #1
    Join Date
    Nov 2008
    Location
    Texarkana, AR, USA
    Posts
    4
    Default "When I move the throttle leve
    "When I move the throttle lever forward, the engine smoothly go to about 2200rpm and when the lever gets about 1/2 way forward, it suddenly surges forward and pins me to my seat??? Otherwise, it seems to run fine. I have had it for a year and only put 2 hours on it and its a very/very low time engine. So far, I have cleaned the carbs, changed the filters and put in a new fuel tank. What do I do???
    Thanks,
    Mal"
  2. #2
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default Is this a new phenomenon or ha
    Is this a new phenomenon or has it always done this?
    Elvin
    Solution One Maritime
  3. #3
    Join Date
    Nov 2008
    Location
    Texarkana, AR, USA
    Posts
    4
    Default "It did it the very first time
    "It did it the very first time I carried it to the lake. Like I said, I have only put 2 hours on it and it probably only has 15 hours on it, total. I am still running an ounce of pre-mix oil to a gallon until I am sure its broken in properly. The surge is very annoying and may be in conjuntion with one of the sensors. The other problem that I am having with it is when I go across a wake, the motor slows to a about 2000rpm and just will not rev back up for 5 to 10 minutes. I have the manual for it and am beginning to get frustrated with the motor. We don't have a certified Nissan mechanic anywhere near here that I know of.
    Thanks,
    Mal"
  4. #4
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default What's your zip code?
    Elvin
  5. #5
    Join Date
    Nov 2008
    Location
    Texarkana, AR, USA
    Posts
    4
    Default 71854
    71854
  6. #6
    Join Date
    Jun 2007
    Location
    TAMPA, FL, USA
    Posts
    1,425
    Default "There are two Tohatsu dealers
    "There are two Tohatsu dealers within 5 miles of you...But, the dealer you need to take it to is:
    Smith's Marine
    318-377-5703
    He's a 1 1/2 hour drive away, but they know their stuff."
    Elvin
  7. #7
    Join Date
    Nov 2008
    Location
    Texarkana, AR, USA
    Posts
    4
    Default "Thanks, I will give them a sh
    "Thanks, I will give them a shout. I thought they were a Yamaha dealer only??? They might be able to figure it out for me.
    mal"
Similar Threads
  1. 1997 Nissan NS40D Tachometer Problem
    By tedhurst in forum Nissan Tohatsu Outboard Forum
    Last Post: 04-02-2009, 08:44 PM
  2. 1995 EFI DT150 V6 BOGGING ON ACCELERATION
    By aenerson in forum Suzuki Outboard Archive
    Last Post: 09-27-2008, 04:44 PM
  3. F 99 acceleration problem
    By rorkin in forum Yamaha Outboard Archive
    Last Post: 09-06-2008, 03:55 AM
  4. 1995 70 HP Evinrude cuts out on acceleration
    By Clint Osteen in forum Johnson Evinrude Outboard Archive
    Last Post: 06-14-2008, 04:59 PM
  5. 1995 50 Liter Ford with Slow Acceleration
    By jonriley56 in forum Volvo Penta Gas Archive
    Last Post: 07-31-2007, 04:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
