Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 4 of 4
Thread: 1992 70hpforce
  1. #1
    Join Date
    Oct 2008
    Location
    Florence, Oregon, usa
    Posts
    2
    Default I recentally bought a 1992 bay
    I recentally bought a 1992 bayliner capri with a 70 hp force I want to get the best performance I can get out of this boat. does anyone have any suggestions. keepon a budget in mind. thanks
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,130
    Default "Assuming the motor is running
    "Assuming the motor is running ok - replace the sparkplugs, change the impeller and lower unit oil unless you have proof the impeller was replaced either this year or last - the gear oil needs to be done annually.
    Get rid of any thoughts about "souping up" the motor. Not worth it and unless you lie to yourself, will make no difference that you can detect.
    Determine if the set-up has the correct prop. Going with lot's of pitch because "this guy" said it would make it faster is pure non-sense. The prop should allow the motor to get to it's optimum wide open throttle (wot) rpm.
    On your particular rig that is about 5000 rpms at full throttle. Significantly lower or higher rpms would indicate an incorrect prop.
    ... A tune up and the correct prop is best way to get max performance from any motor - if you want MORE POWER then you have to refit with a higher horsepower motor - that's the only feasable way..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    Oct 2008
    Location
    Posts
    2
    Default "Grahm thanks for the info. It
    "Grahm thanks for the info. It runs out great now so i will just leave it alone. I don't know alot about outboards, so I thought I'D ASK TO SEE IF THER WERE ANY little tricks up anyones sleeve to make it even better."
  4. #4
    Join Date
    May 2007
    Location
    Posts
    9,130
    Default "Tom, you can spend a bundle t
    "Tom, you can spend a bundle trying to squeeze 1 more horse out of the motor, but in reality it makes such little difference that it is never worth it on a stock motor.
    With that particular rig going from a 70 to a 90 horse would only net you 3 more mph under absolutely perfect conditions - the cost to turn a 70 into a 90 could run you a grand - so is worth 300-400 bucks for every extra mile per hour?
    Old sparkplugs can rob you of 5-10% of your horsepower and the wrong prop up to 15%, so just having it matched and tuned properly will assure you of getting as close to 70 horses as possible..."
    Graham
Similar Threads
  1. 1992 40 hp won't idle or top end.
    By wfw2bar in forum Johnson Evinrude Outboard Forum
    Last Post: 06-14-2010, 09:28 AM
  2. 1992 Mercury 150 HP XR6
    By jschminkey in forum Mercury Mariner Outboard Forum
    Last Post: 05-22-2010, 11:43 AM
  3. 1992 force 90 more HP
    By eric peterson in forum Chrysler Force Outboard Archive
    Last Post: 02-25-2008, 09:19 AM
  4. 1992 175 johnson
    By rwrioux in forum Johnson Evinrude Outboard Archive
    Last Post: 10-05-2007, 07:23 AM
  5. 1992 99 impeller help
    By regalx123 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-08-2007, 09:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
