Water pump replace
frogman
"[b]hi all , im going to repla
"hi all , im going to replace my water pump this winter. is this a stait forward job or is it going to be a pain in the butt? i have 1975 135hp evenrude. or what things should i look for or expect."
"the 2 water tubes........that
"the 2 water tubes........that,is the PITA part...get a factory service manual...u will learn a whole lot about your engine."
There are two plastic guides f
There are two plastic guides for those water tubes that fit into the water pump to help align them. They usually work their way up the tube a bit and need to be pulled down and off to be re-used.
