EVINRUDE WONbT TURN OFF
mjbowhunt
I HAVE A 1991 EVINRUDE 200XP V
I HAVE A 1991 EVINRUDE 200XP V-6 60 DEGREE LOOPER
JUST HAD THE POWERHEAD REBUILT. PUT IT ON THE WATER AN NOW THE ENGINE WON'T TURN OFF WHEN THE KEY IS TURNED OFF. THE ENGINE WILL IDLE DOWN BUT WILL CONTINUE RUNNING. GROUNDED IGNITION KILL WIRE(BLACK AND YELLOW WIRE) STILL WON'T TURN OFF. NEED HELP! THANKS
"I am also having this problem
"I am also having this problem. the guages turn off with the key but the engine continues to run,mine doesnt slow though. i have a 91' V4 140.
my wiring is a mess but it just started doing this and i dont even know where to begin to look."
I had this happen on a 1994 15
I had this happen on a 1994 150 fast strike after a powerhead rebuild. Turned out to be a bad engine ground (from painting block). Do not stop fuel flow to stop motor (damage)! I used the primer on the ignition switch to stop it until I got it fixed.
bassdean
"IMHO, if the ground is ok, an
"IMHO, if the ground is ok, and you are grounding the kill wire, and it won't shut off, the powerpack has failed."
