"Hey guys, my first post here
"Hey guys, my first post here with a trouble motor. I did some searching but couldn't find anything along these lines. I've done some testing and here is what I've found.
Okay so a 2001 or 2002 BF50 came to me for diagnosis. The owner (not 1st owner) told me that it runs for 15/20 minutes or so and then the buzzer comes on, loses the green oil pressure light and it dies, will restart but won't run well at all. Basically limps back in.
I don't have a dyno so I can only run it with the hose and earmuffs attached. It seemed to run well except for two things I noticed. A little lumpy running at idle (nothing major) and definately the water tell tale stream isn't as strong as it usually is. When you'd run it at 2500 rpms for a minute and drop down to idle it seemed like the water stream would practically die off.
I pulled the t-stat and found rubber pieces lodged around there. I pulled the water pump open and it didn't look thaat bad, impeller certainly wasn't missing pieces. I went back to the motor and looked more at it and realized that the silicone sealant around the bottom of the cylinder block and crank half was definately not factory. Someone has been in here before.
Okay fine. I install a new Honda t-stat and full w.pump assembly including the lower housing.
Fire it up and while the water stream was a wee bit better it certainly wasn't as potent as what I'm used to seeing and now it would stay steady at least and not weaken after a bit of fast idling. Oh yeah, lots of zebra muscles noted around the water pump but nothing in any of the water jackets I could see, checked behind the exhaust water jacket cover, clean.
Go to lake, it runs perfect for 20 minutes and dies out with no green light and buzzer. Comes back to me. Okay something is fishy. Spend some time thinking about it and the lumpy idle so I do a compression test just for giggles. 175, 75, 175. OOPS!! Big problem. Pull head off and cyl 2 intake valve visually seems bent. Move the cam to close cyl 2 valves put the head combustion chamber up and put some solvent in cyl 2 combust. chamber and its pouring past the valve out the intake runner.
Okay..... hmmmmm. Take oil filter off and cut it open. Tonnes of dark colored shrapnel in between all the pleates. Dig some of it out put it on my stainless tray, wash it dry and it is totally magnetic. My pick up magnet picks it all up.
No heavy scoring in the cylinder walls, only a little bit of polishing on the load bearing sides, tops of pistons are carboned up.
At this point I think I have multiple bogies. Lets say this motor hydro locked and bent valves, or carboned up and bent valves. Why does it run for 20 minutes then lose oil pressure?
Why is the water stream so weak even with a new pump and totally clean unobstructed water jackets. Could there be a crack in the head or the block.
How old is that oil filter, is the shrapnel in there from before? These are the things going through my head and I don't know which direction to go in while spending the least money for the guy.
Thx a bunch in advance if anyone has any suggestions from experience."
