Mercruiser Stern Drive Swap
tobyj
"Can you replace an Alpha I Ge
"Can you replace an Alpha I Gen I with a Pre Alpha or a Alpha I Gen II? Or, can you mix match uppers and lowers of GenI and Gen II and Pre Aplha?"
"Mix and match upper and/or lo
"Mix and match upper and/or lowers, Series 1, R.MR,Alpha1
Gen II`s only go with Gen II`s uppers and lowers"
"I took the Stern Drive off of
"I took the Stern Drive off of a 1989 Sylvan Speed boat. I put it on a 1988 Chris Craft, I have to replace the stern drive on the Sylvan. Will a Pre Alpha or an Alpha I Gen II bolt up to a Alpha I Gen I bellhousing and work properly?"
no to the Gen II
yes to Alpha
no to the Gen II
yes to Alpha 1 obviously
and Maybe to pre-alpha - it will work if it has the longer driveshaft- there were 2 different lengths and the shorter one may not engage the engine coupler properly
"Ayuh,....
The Gen.II drive
"Ayuh,....
The Gen.II drives are a Totally Different drive,+ will Not interchange,..."
