454 compression
roperfect
"We just did a compression che
"We just did a compression check on a 1996 37 Silverton with 454 XL Crusaders, with 400 hours. All the cylinders were reading 125 psi with very little variation 5 psi at most. What should compression be on these motors?"
Boat with twin 1997 Crusader 4
Boat with twin 1997 Crusader 454 XLI throttle body engines. Check engine light has come on on port engnes. What scan tool do I purchase to read codes and turn light off. OBD2 scanner does not work due to wiring harness plug.
Help!!
