Mercury 30hp efi
J
JEFFYDALMER
Guest
a friend recently said my 2008
a friend recently said my 2008 30efi 4st is actually made by tohatsu is this true?
thank you
is it a 3 cylinder if so proba
is it a 3 cylinder if so probaly but if it the 2 cylinder one its a yamaha
"THANK YOU FOR RESPONDING,IT&#
"THANK YOU FOR RESPONDING,IT'S 3 CYLINDER EFI 2008
COULD YOU TELL ME IF ANY WATER SHOULD BE PUMPING FROM REAR WATER HOLE? THE TELLTALE IS STRONG AND ALWAYS PUMPING,BUT ONLY STEAM COMES OUT THE BACK.
THANKS AGAIN."
"It's a Tohatsu and yes, t
"It's a Tohatsu and yes, there should be some water coming out. Most will come out through the propeller, but you should be getting some spray out through the motor leg port."
