Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 6 of 6
  1. #1
    Default my engine is hard to start eve
    my engine is hard to start even when it is warmed up i have to crank crank crank it and even choke it could someone tell me what could be my prob. thanks alot
  2. #2
    Join Date
    Apr 2008
    Location
    Auckland New Zealand
    Posts
    145
    Default Might be compression is low or
    Might be compression is low or a crank seal is stuffed....could be carbs...run all the comp tests before spending any money.
  3. #3
    Default what should i do first and how
    what should i do first and how do i check it out before spending any money? thanks
  4. #4
    Join Date
    Apr 2008
    Location
    Posts
    145
    Default "Compression check first and f
    "Compression check first and foremost, you may need to bribe your local car mechanic to help you with this...they should be above 100 and within 10% of each other....120+ is good.
    Dunno if you are mechanically minded but pulling your carbs apart, cleaning and adjusting everything and also your fuel lines and filter.
    None of this will require buying any parts unless you find something bad in the carbies."
  5. #5
    Default thanks for everything
  6. #6
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default if compression is fine rebuil
    rebuild the carbs and replace the fuel pump and all lines
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
Similar Threads
  1. 1994 Force 90hp Missing
    By fastdaddy55 in forum Chrysler Force Outboard Forum
    Last Post: 07-27-2010, 01:27 PM
  2. 1993 90hp force outboard engine canbt start
    By cambie10162 in forum Chrysler Force Outboard Forum
    Last Post: 02-16-2010, 03:22 AM
  3. 98 FORCE 90HP
    By MDC in forum Chrysler Force Outboard Archive
    Last Post: 07-20-2008, 09:39 PM
  4. 1997 90hp Force
    By voyagerv20 in forum Chrysler Force Outboard Archive
    Last Post: 05-07-2008, 09:50 PM
  5. 1997 90hp Force
    Last Post: 12-28-2007, 02:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
