MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Results 1 to 4 of 4
  1. #1
    mmeburges1's Avatar
    mmeburges1 Guest
    Default " What is the best method for
    " What is the best method for cleaning the gunk from the outside of a carb body. Is there something I can use to soak it in.
    Thanks,
    Mike "
  2. #2
    Default Hello Do you have Auto Zone s
    Hello Do you have Auto Zone store in your area?
    They sale a carb. cleaner in a yellow can that
    is really good for that. Do not get it on a
    painted surface will curl paint right up. Tom
  3. #3
    Join Date
    Nov 2005
    Location
    Posts
    424
    Default " Hi, I'm not sure wher
    " Hi,
    I'm not sure where the carbs you want to clean are located, but if they are installed, it's probably a bad idea.
    Carb cleaner can melt just about anything that is not metalic. A little over-spray may be OK, but if you go soaking down rubber hoses and plastic fittings, there's a good chance you'll warp, weaken, or even melt them. In the manuals I have they tell you to remove anything that is non- metal before you soak carb parts, for good reason.
    Jon "
  4. #4
    John ODillon's Avatar
    John ODillon Guest
    Default " I need to know how to grease
    " I need to know how to grease the lower unit on an old Clinton outboard (5 horse). It has no plug screws, only 4 mounting bolts which hold the bottom cap with the keel to bottom 1/2 of the chunk. "
Similar Threads
  1. Honda 50 Carb Cleaning........Help!!
    By Cupajo in forum Honda Outboard Forum
    Last Post: 09-22-2010, 09:57 AM
  2. 2002 50 hp Carb Cleaning
    By captb in forum Honda Outboard Forum
    Last Post: 02-23-2010, 10:50 PM
  3. 99 carb cleaning options
    By lynnie in forum Yamaha Outboard Archive
    Last Post: 06-11-2009, 11:48 AM
  4. Cleaning Carb AFB
    By the_lake in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 11-24-2007, 08:45 PM
  5. Carb Cleaning
    By mike911 in forum Mercury Mariner Outboard Archive
    Last Post: 08-09-2006, 10:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
