Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2008
    Location
    caldwell, tx., us
    Posts
    2
    Default "my boat was running fine then
    "my boat was running fine then plastic piece at dist. broke that adj timing with throttle adv. I orderd the part and want to know if anyone knows how to adjust the timing (what to set screw to i have my timing marker on the block and have a degree wheel on flwheel . Im a truck mechanic so just really need info like if you just need timing light,what speed motor should be and what actual timing mark to be on , thanks"
  2. #2
    Join Date
    Apr 2008
    Location
    Auckland New Zealand
    Posts
    145
    Default "You need a timing light to ch
    "You need a timing light to check the timing properly, start by adjusting all the linkages as per the manual.
    Check timing at idle and at full advance (WOT)...maybe someone here can give you the details as I no longer have the manual."
  3. #3
    Join Date
    Oct 2008
    Location
    caldwell, tx., us
    Posts
    2
    Default Thanks my manual is lost. they
    Thanks my manual is lost. they have one u can buy that covers those years on barnes and nobles sight. guess i need to order it. Just hope it works its cover alot of years on chrysler engines
  4. #4
    Join Date
    Apr 2008
    Location
    Posts
    145
    Default "They didn't change much i
    "They didn't change much in the 70's, the manual I had covered all you need to know...was a Clymer manual."
Similar Threads
  1. 1979 40 hp high idle timing
    By Sea Esta34C in forum Mercury Mariner Outboard Forum
    Last Post: 07-04-2017, 12:00 PM
  2. 1979 chrysler 7.5hp
    By bvdpm1 in forum Chrysler Force Outboard Forum
    Last Post: 07-23-2010, 09:46 AM
  3. 1979 chrysler 75 hp
    By tjanddj in forum Chrysler Force Outboard Forum
    Last Post: 08-18-2009, 12:08 AM
  4. Chrysler 115 1979
    By jeff pinion in forum Chrysler Force Outboard Archive
    Last Post: 04-10-2004, 06:53 PM
  5. Setting timing on a 1979 Evinrude 175
    By kenny in forum Johnson Evinrude Outboard Archive
    Last Post: 03-22-2004, 08:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
