Click for Volvo Penta manuals!
Results 1 to 2 of 2
  1. #1
    tommy mac's Avatar
    tommy mac Guest
    Default i just fitted new pully and cl
    i just fitted new pully and clutch on compressor and when i turn on isolater switch the clutch clicks and when i start engine the compressor is on constantly anyone any ideas please
  2. #2
    Default there is a control module in t
    there is a control module in the electric box. it contols the negative supply to the clutch.the positive supply comes from the starter motor and is live as soon as the battery switch is on.the negative is switched on/off by the control module.sounds like the control module or short to negative on the harness from the clutch.diconnect control module and check betweeen pins S1 AND 31- on the module.should be open circuit.if not replace module.old clutch may have damage relay contacts in module
Similar Threads
  1. KAD32 compressor noise
    By Camalandy in forum Volvo Penta Diesel
    Last Post: 08-17-2012, 08:41 AM
  2. Kad43 Compressor Problem
    By mattco in forum Volvo Penta Diesel
    Last Post: 06-15-2010, 05:06 PM
  3. Kad 43 compressor clutch slipping
    By antsinupants in forum Volvo Penta Diesel
    Last Post: 04-20-2009, 05:25 PM
  4. Volvo KAD44 Compressor
    By billarse in forum Volvo Penta Diesel
    Last Post: 01-18-2009, 05:57 AM
  5. Kamd 300 compressor
    By permit4u in forum Volvo Penta Diesel
    Last Post: 12-21-2008, 02:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
