Honda BF8a
K
Kendall Nasi
Guest
"Motor will not idle with chok
"Motor will not idle with choke pushed all the way in, motor dies. Runs at half choke."
"Fuel today, if left sitting i
"Fuel today, if left sitting in the carburetor too long will plug up the small jets in the carburetor.So clean the carburetor (take it apart to do so ) and run the fuel out if you do not use it regularly."
Cleaned carb and stil the same
Cleaned carb and stil the same thing. With choke pushed in if I don't rev the throttle the motor dies.
"I had that same problem with
"I had that same problem with my BF75, an earlier version of the same engine. I ended up taking my carb apart FOUR times before finding the blockage. Running carb cleaner thru it is NOT enough. The blockage is in the idle circuit, which is a seperate (winding and twisting!) carb circuit than the main one. There is a fixed, not removeable metering jet in that carb (at least in mine) that has a very tiny hole that does not respond to the usual soak and blow cleaning. I ended up cleaning it up with a 30AWG copper wire, i.e., a single strand from a multi strand copper wire.
A can of "canned air" available from Staples or RAdio Shack with the plastic straw extension affixed is a handy tool as well. This is to be used in addition to the wire, not instead of."
I had a same problem with my 9
I had a same problem with my 9.9 - I used plenty of stabilizer and the blue stuff - that is Starbrite startron gasoline additive. Plus I purchased some new gas with cleaner in it. I then installed a fuel water separator and filter. Then cleaned the carb. I have had no issues since I have been doing this. Also at end of season use the old gas in your truck. Start the season with new gas and treat.
