2003 81 volvo gi bad smell exhaust
doral36
"Dose anyone know what would c
"Dose anyone know what would cause a burnt plastic type of smell only when i am taking off or coming to a stop . I checked for any over heating ,did not find anything ,smells fine at idle.thanks sam"
"Hi
I was reading the posts
"Hi
I was reading the posts about the exhaust flappers,now I know where they are on the drive. I have dps drives, my exhaust does no have a bellow it only has a straight rubber tube that couples with drive when it lowers down. Is this set up ok.
Thanks Sam"
UPDATE ON THAT SMELL FROM EXHA
UPDATE ON THAT SMELL FROM EXHAUST IT`S LIKE BURNT FIBERGLASS .CAN ANYONE HELP THANKS SAM
That means that you seawater c
That means that you seawater cooling system does not have enough flow. Most likely your exhaust elbows have become restricted and/or your seawater pump needs to be serviced.
Hi Dave
My impellers were jus
Hi Dave
My impellers were just changed and when engine is running I can hold my hand on the risers fells like normal temp
