Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 2 of 2
  1. #1
    brian rae's Avatar
    brian rae Guest
    Default New boat owner 1986 force 125
    New boat owner 1986 force 125 hp. i removed lower unit to replace water pump and the shift rod became unthreaded from the pivit point. what would cauce this rod to do this and what is the proper fix ??
  2. #2
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    795
    Default "Brian, Turning the rod wou
    "Brian,
    Turning the rod would do it and would also be the most likely reason. Possible someone thought that turning it would be how the shift is adjusted. If the pivot bolt has not been removed you may be able to turn it back in without tearing into the gearcase.
    Good Luck"
Similar Threads
  1. Lower unit - how to take apart
    By lilernie in forum Mercury Mariner Outboard Forum
    Last Post: 05-31-2010, 12:01 AM
  2. Reinstalling the lower unit back on to the upper unit
    By youngsboat in forum Mercruiser Sterndrive Archive
    Last Post: 08-26-2009, 01:05 PM
  3. 77lower unit swap with 78 lower unit
    By ed270electric in forum Johnson Evinrude Outboard Archive
    Last Post: 08-31-2007, 10:10 PM
  4. Replacing Lower Unit on 1998 Force 120 Will 1996 Lower Unit Work
    By Mike Cann in forum Chrysler Force Outboard Archive
    Last Post: 11-01-2006, 12:58 PM
  5. 1981 OMC lower unit interchange with 9596 unit
    By merlin in forum Johnson Evinrude Outboard Archive
    Last Post: 06-15-2003, 02:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
