"The engine will turn over fin
"The engine will turn over fine, I am getting fuel but no spark. I disconnected the engine wiring harness from the boat then removed the blk/yellow wire(kill switch) from the switch box. Engine fires normally. Mechanic said it was power pack/switch box. He put a new switch box on, no spark. He said it might be the rectifier. Tried that, no luck. Anyone had a similar problem? Suggesions?
Thank you,
Mike"
Thank you,
Mike"
