Results 1 to 2 of 2
    Sep 2008
    Washington, DC,
    4
    Default Need to unplug/open line betwe
    Need to unplug/open line between exhaust manifold and coolant overflow tank. Overflow tank connects to exhaust manifold by an elbow fitting on top of the manifold. After entering the manifold the line does an immediate 90% turn and travels along the top of the manifold and terminates at the edge of the fill opening (radiator cap type). This tube seems to be pinched shut (however it could be plugged). How do I open up this tube? I've tried a stiff wire with no luck. Does this tube need to terminate/open at the fill opening? Could I pull off the elbow fitting an drill an opening thru the tube straight down?
    Sep 2008
    Washington, DC,
    4
    Default Found and removed the obstruct
    Found and removed the obstruction. Problem fixed.
  1. omc cooling system
    By dimitrimfogal in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-09-2010, 11:30 PM
  2. Westerbeke W46 Sludge in Cooling System
    By wyeriver in forum Universal and Westerbeke
    Last Post: 11-07-2009, 12:31 PM
  3. Westerbeke 77 Generator cooling problem
    By Jan Maler in forum Universal and Westerbeke
    Last Post: 07-14-2008, 10:04 PM
  4. Closed water cooling system verses a raw water cooling system
    By Dan Stephens in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 02-19-2008, 12:56 AM
  5. 318 cooling system
    By diercoff in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 06-24-2007, 04:34 PM
