Two dead cylinders on volvo penta aq130c
smcnamara
"changed dist cap, points, con
"changed dist cap, points, condenser, rotor and wires...compression test all at 170....3 and 4 not firing...any advice would be appreciated..thanks."
"The AQ130C has two twin carbs
"The AQ130C has two twin carbs (Solex)Silly question have you checked the diaphragm opp Cylinders 3 & 4 or alternatively check the fuel injectors for blockage, if you want the workshop manual give me a shout"
"Did you set the point dwell c
"Did you set the point dwell correctly? If your distributor is in good condition, you may consider upgrading to a Pertronix electronic ignition kit.
Also, are the ignition leads going to the right cylinders? That is, any chance you have swapped wires 3 and 4?
And have you synchronized the carbs?"
