Click for Bukh manuals!
Results 1 to 2 of 2
  1. #1
    Default If anyone here has some experi
    If anyone here has some experience with the Bukh DV24 I could use some advice. Having trouble hand starting so I'm looking for some help with decompression and hand cranking.
    cheers
    tdw
  2. #2
    ian sanford's Avatar
    ian sanford Guest
    Default "tdw, it is a bit of a strugg
    "tdw,
    it is a bit of a struggle cranking on your own, i have a 28hp in sydney , you need to decompress the valves ( my decompreesion lever was very tight which i found was the rocket cover was done up to tight i released the bolts a 1/4 turn and that curred all my problems) you need to get the motor spinning quite fast
    ian"
Similar Threads
  1. Bukh DV24 - Pressure in sump
    By Mark Finlay in forum Bukh
    Last Post: 10-05-2011, 11:12 PM
  2. Tapits on a dv24 help
    By vtrgirl in forum Bukh
    Last Post: 11-21-2008, 03:52 PM
  3. 318 RIGHT HAND ROTATION
    By pete2225 in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 11-09-2008, 09:19 AM
  4. Changing a right hand propr to a left hand prop
    By beeeman in forum Volvo Penta Gas Archive
    Last Post: 10-14-2007, 04:16 PM
  5. Can I run both lt amp rt hand prop
    By briant10 in forum Volvo Penta Gas Archive
    Last Post: 04-09-2006, 01:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
