Click for Volvo Penta manuals!
Results 1 to 3 of 3
  1. #1
    Join Date
    Jul 2007
    Location
    North Charleston, South Carolina, USA
    Posts
    52
    Default "My boat has a fly bridge and
    "My boat has a fly bridge and two sets of instruments. It has a TAMD41p engine. When I bought it, the surveyor pointed out that the upper temperature gauge read about 15 degrees higher than the lower gauge and the lower gauge agreed with his IR thermometer.
    Are there two sending units or are both gauges connected to the same sending unit? Where is the sending unit or units?
    If there is only one sending unit, I would assume the gauge is defective and cannot be repaired. Where can I get a replacement?"
  2. #2
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "The temp instrument is basica
    "The temp instrument is basically an ohm-meter. The hotter the engine, greater resistance: higher temp indication. As for different readings: The longer the cables, the bigger resistance: the higher temp reading.
    You may not get much difference by changing instrument.
    Suggest You do a cross-change to check."
  3. #3
    Join Date
    Jul 2007
    Location
    Posts
    52
    Default "Well if a higher resistance m
    "Well if a higher resistance means a higher temp reading, I suppose it could be corrosion on the connector also. Thanks for the info, I'll check the wiring and swap the gauges if it's not the wiring."
Similar Threads
  1. Temperature Gauge
    By luhrern in forum Johnson Evinrude Outboard Forum
    Last Post: 05-23-2010, 10:37 PM
  2. Temperature gauge for a BF225
    By chawk_man in forum Honda Outboard Archive
    Last Post: 04-19-2009, 08:51 PM
  3. Temperature gauge amp Temperature switch on 90 johnson
    By gjackman in forum Johnson Evinrude Outboard Archive
    Last Post: 05-27-2008, 05:57 PM
  4. Temperature gauge
    By nakotnt in forum Mercruiser Sterndrive Archive
    Last Post: 05-02-2007, 11:55 PM
  5. Temperature Gauge Not Working
    By joelf in forum Mercruiser Sterndrive Archive
    Last Post: 04-24-2006, 02:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
