Results 1 to 3 of 3
  1. #1
    Default "Just picked this boat up for
    "Just picked this boat up for a pretty decent price and am trying to get it ready to take out for a test run. My questions are pretty simple: How do I know if I have an electric or point start? (I was asked when I tried to order spark plug wires for the engine (Mercruiser 888)). Does anyone know where I can order the trim switch for raising and lowering the outdrive? I am new to the boating world, so your help and patience is appreciated.
    Thanks!"
  2. #2
    Join Date
    Feb 2006
    Location
    Former Brew City, WI,
    Posts
    26
    Default "Were you asked if the boat ha
    "Were you asked if the boat has an electronic or point type distributor?
    As far as the trim switch, clean ALL the contacts, don't just look at them and think, "That's alright"."
  3. #3
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "Look under the dist. cap to s
    "Look under the dist. cap to see if there are points or if it was upgraded to electronic ignition.
    Read the last few parag.
    <center><table border=1><tr><td>[img]http://www.marineengine.com/discus/icons/attachment_icon.gif""" align=left alt=""application/vnd.openxmlformats-officedocument.wordprocessingml.document"">how the trim works
    How the trim.docx (12.6 k)</td></tr></table></center>"
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
Similar Threads
  1. 1976 70 HP Evinrde, many questions.
    By jim18611865 in forum Johnson Evinrude Outboard Forum
    Last Post: 11-14-2010, 11:02 AM
  2. 1976 OMC Sterndrive Questions
    By mackinthebox in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-02-2008, 06:58 PM
  3. 1976 Aristocraft with 120 hp Mercruiser FOLLOWUP Questions
    By dan Moriarty in forum Mercruiser Sterndrive Archive
    Last Post: 07-17-2006, 05:26 PM
  4. 1976 85HP Evinrude Questions for Joe Reeves
    By Joe Gorman in forum Johnson Evinrude Outboard Archive
    Last Post: 05-09-2004, 09:44 AM
  5. 1976 55hp Evinrude Several questions
    By Chris Kinney in forum Johnson Evinrude Outboard Archive
    Last Post: 04-17-2003, 06:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
