"Voltage Gauge Fluctuation on
"Voltage Gauge Fluctuation on my 1988 Mercruiser 3.7. I have read many discussions regarding the Voltage Regulation System on the 3.7 Mercruisers as being "God Awful". The boat I purchased from a friend has been very well maintained and has only 153 hours on the 20 yr/old engine. The engine seems to runs well with the exception of the voltage gauge. It normally runs @ approx. 12.5/ 13 volts. Then all of a sudden the gauge will peg out @ 16 volts. While the voltage is @ 16 and I use the trim or any other accessory requiring voltage, the gauge goes crazy (jumps around) and the engine starts to sputter. Has anyone had this problem and could this be the V/R going bad. Note: I have two new batteries on-board and have had them tested OK. Thanks, Rick."
