Ignition issue
mn_native
"I am stuggling with an igniti
"I am stuggling with an ignition problem on a 1988 100 HP Merc SN ob329871. It is the model with 4 individual coils.
Problem:
No spark on # 2 cylinder.
I swapped input wire to coil from # 1 to 2 and turned over motor, no spark on # 1 now and have spark on # 2, in other words it does not appear to be anything with the coil, it follows the input to the coil. I have crosschecked all input lines to coil with DVOM and have equal resistance readings on all coil inputs. I have visually inspected all wiring I can see and see no issues. This motor under the cowling is like brand new, it has less than 300 hours on the motor so there are no visual signs of wear or anythinng disconnected. I have now reached my level of incompetence and would appreciate guidance on what to look at next.
Thank you
Rob"
Thank you for the information.
Thank you for the information. I was able to get spark on all 4 but it is intermittent on #2. I guess I need to find a switch box.
THis is a great forum and I really do appreciate the help.
Rob
