Atomic 4 Marine engine
J
Joseph Moran
Guest
"Engine runs great. Just repla
"Engine runs great. Just replaced both fresh & salt water pumps. Then flushed out fresh water cooling system. Engine has not overheated. But now oil pressure has droped & oil is milky. I installed a remote fresh water grease pump to grease pump seal, But did not replace the fresh water pump seal.My thought is that I may have over greased the old seal and now water is getting into the oil sump causing the oil to get milky & the oil pressure to drop. Should I replace the fresh water pump seal,pump out old oil and replace with new oil & see if this is the fix. What are the thoughts out there. Please E-mail me back atomic 4 subject. To [email protected]"
