Results 1 to 2 of 2
  1. #1
    Default I have tested my trim sending
    I have tested my trim sending unit and it does not work. The trim gauge stays in full up and does not move with trim in full down. I even checked witha ohmmeter and it stays at 200 ohms while manually moving the arm on the sending unit all the way each way.
    I can not find one. Where I can get one? I don't have the part number either.
    It is on a 89 cobra 4.3L
  2. #2
    Russ Arnold's Avatar
    Russ Arnold Guest
    Default "Just got a new sending unit t
    "Just got a new sending unit through Doug Russell Marine in Mass. for my '88 7.5L King Cobra. Try wwww.dougrussell.com. It should run you around $100 with shipping, but they'll send you their catalog, which is about as thick as a phonebook!"
Similar Threads
  1. trim sending unit
    By scorpion in forum Volvo Penta Gas Engine Forum
    Last Post: 05-26-2010, 10:00 PM
  2. Tilt n trim sending unit
    By dannyvan in forum Johnson Evinrude Outboard Archive
    Last Post: 04-15-2009, 08:45 AM
  3. Trim gauge sending unit bad
    By leros in forum Johnson Evinrude Outboard Archive
    Last Post: 06-30-2008, 11:06 AM
  4. How to replace trim sending unit
    By mossie3 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-01-2008, 10:58 PM
  5. Trim Sending Assembly Unit
    By walleyes4u in forum Johnson Evinrude Outboard Archive
    Last Post: 09-28-2006, 08:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
