Warning buzzer 95 intruder
"It sounds at 'low'oil
"It sounds at 'low'oil', but no SLOW (normally).
No Oil -SLOW
Fuel restriction - SLOW
High temp -SLOW
If buzzer goes ON but no slow, disconnect the oil-tank (brown).
Smoke at start up, might be caused by pressure in the oil-tank or over priming."
Is the brown wire the low oil
Is the brown wire the low oil sensor wire and is your slow buzzer the long buzzer i'm experencing?
thanks jeff
"It is a 'double' cabl
"It is a 'double' cable coming from the oil tank. One is to ground (black), the other is connected to a brown on engine.
SLOW means that engine speed is limited to 2500-3000 by the power pack. Pushing throttle above that, engine starts 'shaking'.
The Low Oil alarm does not have this function. A blocking diode in the engine wire harness prevents the signal going to the power pack."
