Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 5 of 5
  1. #1
    Join Date
    Aug 2008
    Location
    Brick, NJ, usa
    Posts
    4
    Default "I have a 90 HP Force on a 94
    "I have a 90 HP Force on a 94 Proline 17 foot center console. 13 1/2 X 17 pitch prop. Only getting 4500 WOT when I should be getting between 5000 and 5500 WOT, Checked the throttle adjustments and everything looks good. Tried a 13 3/4 X 15 prop and did not get the 300-400 additional RPM I was suppose to get. Changed the lower unit lubricant,( needed it badly) What else could be wrong that is causing such poor performance gewtting up on plane. My next step is possibly a set of manual trim tabs, or maybe a wing on the outboard. anyone have any suggestions?}"
  2. #2
    Join Date
    Apr 2008
    Location
    Auckland New Zealand
    Posts
    145
    Default "Should be on the plane before
    "Should be on the plane before WOT.....is your tilt/trim adjusted correctly? How about weight distribution on board, tried moving the fuel tank forwards? Permatrim may be a better way to go than trim tabs."
  3. #3
    Join Date
    Aug 2008
    Location
    Brick, NJ, usa
    Posts
    4
    Default "I tried the trim all differen
    "I tried the trim all different ways. no difference. Cant move the fuel tank, at least not that I know of, its built in. I looked at the permatrim. I think Im going to try that. Appreciate the advise. took it out abain this morning, getting aprox 4600 RPm @ WOT, My son and I were the only ones on. looking at an additional 380 lbs"
  4. #4
    Join Date
    Apr 2008
    Location
    Posts
    145
    Default Have you done a compression te
    Have you done a compression test and checked the ign timing??
  5. #5
    Join Date
    Aug 2008
    Location
    Brick, NJ, usa
    Posts
    4
    Default "The compression is all good.
    "The compression is all good. I have not checked the timing yet. Ill try that this weekend.. Thanks again..I also had a clogged fuel filter, so I suspect some dirt in the carbs. I plan on a carb rebuild this winter."
Similar Threads
  1. Canbt get on plane
    By cliff_mygatt in forum Mercruiser Sterndrive Archive
    Last Post: 07-30-2009, 11:43 AM
  2. Power trim problem on plane
    By gkm24 in forum Mercruiser Sterndrive Archive
    Last Post: 08-05-2008, 05:08 AM
  3. Will not plane out Help
    By rdphillips in forum Volvo Penta Gas Archive
    Last Post: 06-12-2007, 08:28 AM
  4. Can%60t get on plane
    By preacher_man in forum Mercury Mariner Outboard Archive
    Last Post: 03-13-2007, 10:56 AM
  5. Wonbt get on plane
    By roberth in forum Johnson Evinrude Outboard Archive
    Last Post: 10-28-2006, 05:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
