Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 3 of 3
  1. #1
    Join Date
    Sep 2008
    Location
    Statesboro, Georgia,
    Posts
    2
    Default "Recently purchased a boat wit
    "Recently purchased a boat with an 85hp chrysler on it. Not sure what year(70's??). It has a breaker point distibutor and type IV ignition. Im sure its not one of the earlier models. I couldnt get it to start thought there was no fire but took it to a marine shop to give it a good look over and they said all cylinders are firing. Its a project boat so I am planning doing most of the work myslef. He also said the points needed to be replaced. After getting it back I tried again and nothing. They said everything else looked fine, just needs new points. Any ideas?? thanks"
  2. #2
    Join Date
    Apr 2008
    Location
    Auckland New Zealand
    Posts
    145
    Default Try new points and then static
    Try new points and then static time the ignition and give the carbs a good clean and re-set all the linkages. Make sure you have at least a 550 cca battery attached and that the battery leads are not too long for their thickness as it may not be spinning fast enough.
  3. #3
    Join Date
    Sep 2008
    Location
    Posts
    2
    Default "Thanks Andy, just purchased s
    "Thanks Andy, just purchased some points and I will try that. I will go check that battery. If anyone else has any ideas let me know. Thanks"
Similar Threads
  1. 1973 johnson 85hp problems
    By eyehunter in forum Johnson Evinrude Outboard Forum
    Last Post: 09-02-2010, 06:37 PM
  2. 1975 85hp problems
    By oneeyemike77 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-16-2008, 10:06 PM
  3. Problems w 1976 85hp Evinrude
    By Kirk Eaton in forum Outboard motors archive 2000-2004
    Last Post: 03-30-2003, 11:24 AM
  4. Problems with b78 Evinrude 85hp
    By Joe Dawson in forum Outboard motors archive 2000-2004
    Last Post: 07-12-2001, 04:29 PM
  5. 69 Evinrude 85hp Problems
    By Joseph Staley in forum Outboard motors archive 2000-2004
    Last Post: 06-01-2001, 12:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
