Results 1 to 5 of 5
  1. #1
    Default I have a 1989 evinrude 70 hp o
    I have a 1989 evinrude 70 hp outboard model number is EL70ELCEM. I want to change my vro to a older version fuel only pump and use 50/1 mix. Would like information on what year and model number of fuel pump I could use. I would like to take vro out of motor.
  2. #2
    Join Date
    Feb 2004
    Location
    Posts
    340
    Default "If you remove and plug the oi
    "If you remove and plug the oil supply line to the VRO, you now have a fuel pump only, and you will now need to mix the oil/gaS TO 50/1"
  3. #3
    Default "Thanks for your info Tom, I w
    "Thanks for your info Tom, I would still like to remove the vro unit from the motor. I am wondering if I could use a fuel only pump for a later model year 70s or early 80s engine. thank's."
  4. #4
    Join Date
    Feb 2004
    Location
    Posts
    340
    Default Any fuel pump from the 80'
    Any fuel pump from the 80's on will work..try to stay close to your HP range...15-20 HP difference will work OK..
  5. #5
    Default "Thanks again Tom, I will get
    "Thanks again Tom, I will get a late model 80s fuel pump in my power range. GREAT SITE,GOOD INFO."
Similar Threads
  1. Replacing automotive fuel pump with marine type fuel pump on a 318 Chrysler
    By eetgar in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 07-13-2010, 08:09 AM
  2. Info to change from vro to fuel pump only 1986 40 hp
    By tonym in forum Johnson Evinrude Outboard Forum
    Last Post: 01-09-2010, 07:05 PM
  3. 15hp Fuel pump change
    By Joe C in forum Johnson Evinrude Outboard Archive
    Last Post: 09-30-2007, 09:42 AM
  4. Fuel pump change VRO
    By Darnell Morris in forum Johnson Evinrude Outboard Archive
    Last Post: 09-14-2006, 10:07 PM
  5. Replies: 2
    Last Post: 09-05-2006, 09:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
