Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 4 of 4
  1. #1
    Default "I had picked up a rebuilt tri
    "I had picked up a rebuilt trim motor for my 1988 125 hp It has 3 wires but the old one had two. I connected the black to the ground on the battery. The blue to the up wire on the boat. It works, but the green does not. Any ideas? Thanks."
  2. #2
    Join Date
    Apr 2008
    Location
    Grandbay, New Brunswick, Canada
    Posts
    123
    Default "Re tilt issue,you need to tra
    "Re tilt issue,you need to trace the 2 exsting wires up to motor and find the relays which reverse the polarity in which causes the pump to operate in opposite directions, when you find email and we will go from there. P.S what was the original pump problem.
    Michael"
  3. #3
    Default "The relays are in the motor h
    "The relays are in the motor housing which have circit breakers inline. The original pump had stopped working. I had tried to wire it directly to the battery it did not work. After looking inside, it was full of rust from a water leak."
  4. #4
    Join Date
    Apr 2008
    Location
    Posts
    123
    Default "OK, Did you, or can you test
    "OK, Did you, or can you test the relays? i will go to my manual and send you the wiring diagram,Iam one of those tech's that can do it but just cannot explain it. Sorry for the delay, If one of your relay's are bad i can send you one FREE you pay shipping. let me know.
    michael"
Similar Threads
  1. Trim n tilt wires 1987 yamaha 50hp
    By Rob Merc in forum Yamaha Outboard Forum
    Last Post: 09-20-2010, 12:21 AM
  2. 1987 mariner 75hp 3 cyl trim motor wires?
    By POS ponton in forum Mercury Mariner Outboard Forum
    Last Post: 06-22-2010, 08:51 PM
  3. trim/tilt motor
    By daneryden in forum Honda Outboard Forum
    Last Post: 05-02-2010, 10:44 AM
  4. Tilt Trim Gauge Wires
    By roybowe in forum Johnson Evinrude Outboard Archive
    Last Post: 08-07-2007, 10:26 PM
  5. Outdrive tilt n trim wires
    By rich_b in forum Mercruiser Sterndrive Archive
    Last Post: 06-17-2007, 05:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
