Bilge pump
sat1425
I have inherited a 1986 bass t
I have inherited a 1986 bass tracker. The bilge pump does not work. How many bilge pumps are usually on a boat of this type? I can see 2 at the rear.
"usually only 2 ,if they both
"usually only 2 ,if they both arent working check you have power to the switch ,it is unlikely they both have stopped, unless they have been left turned on"
"They are pretty beat up. I wi
"They are pretty beat up. I will double check if one of them is an aerator. In any case, would there be any other bilge pumps located any where else other than the back of the boat?
thanks"
