Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 8 of 8
  1. #1
    MWhitman's Avatar
    MWhitman Guest
    Default I recently purchased a boat th
    I recently purchased a boat that has a 89 force 125hp 2 stroke ... first time i took it out had thick smoke coming out of the exhaust only at idle or low rpms. changed the spark plugs put a new fuel filter and still very thick smoke coming out at low rpms. any suggestions? Im stumped.
  2. #2
    Join Date
    Apr 2008
    Location
    Grandbay, New Brunswick, Canada
    Posts
    123
    Default "Sounds like old fuel or incor
    "Sounds like old fuel or incorrect mixture, is the mixture 50 to 1"
  3. #3
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,131
    Default "Yes, I would suspect 1) o
    "Yes, I would suspect 1) old fuel 2) too much oil in the mix or even 3) motor had been stored - fogging in the cylinders.
    New gas, 50:1 with a quality TCW-3 rated marine oil and take her out for a good run - clean all the cooties out and see if she still smokes.
    Smoking on a 2 stroke is not indicative of a problem the way it is on a 4 stroke.....
    If a 4 stroke smokes you have a problem, if a two stroke smokes you usually have too much oil in the gas...."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  4. #4
    Mwhitman's Avatar
    Mwhitman Guest
    Default Hey ya that was one of the fir
    Hey ya that was one of the first things I did when I got the boat put new fresh fuel in it with a 50:1 fuel oil ratio with the manufactures recomended Quicksilver 2 stroke marine oil... still smoking heavily
  5. #5
    Join Date
    May 2007
    Location
    Posts
    9,131
    Default "How is the idle - smooth? any
    "How is the idle - smooth? any hitches/hiccups sneezes etc? or is it fine, just alot of smoke?"
    Graham
  6. #6
    Mwhitman's Avatar
    Mwhitman Guest
    Default "the idle runs smooth once its
    "the idle runs smooth once its up to running temp, when its cold and you shift into nutruel or reverse it dies."
  7. #7
    Join Date
    May 2007
    Location
    Posts
    9,131
    Default "Ok, that sounds like a jet is
    "Ok, that sounds like a jet issue (low speed) in the carbs. Could simply be an adjustment but this motor is pushing 20 years old and removal/disassembly/cleaning and at least gasket kits if not rebuild kits would probably be in order...."
    Graham
  8. #8
    Mwhitman's Avatar
    Mwhitman Guest
    Default darn someone told me that and
    darn someone told me that and I was hoping it wouldnt be that o well... thanks for the help...
Similar Threads
  1. force 125 t/t oil 1989 125hp
    By bass_tracker in forum Chrysler Force Outboard Forum
    Last Post: 05-10-2010, 11:49 AM
  2. 1989 90HP Force L drive plugged exhaust
    By yaplej in forum Chrysler Force Outboard Archive
    Last Post: 07-28-2008, 11:54 PM
  3. Force 1989 125hp
    By tellmeslo55 in forum Chrysler Force Outboard Archive
    Last Post: 04-07-2007, 09:08 PM
  4. 1989 125hp force
    By papakevin in forum Chrysler Force Outboard Archive
    Last Post: 03-23-2006, 04:51 PM
  5. 1989 Bayliner with Force 125hp LDrive lower unit oil weight
    By george in forum Chrysler Force Outboard Archive
    Last Post: 08-18-2003, 12:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
